Dear all,
I am trying to import data from Hysys to use it in Flarenet. Each time I use import option from flarenet, I have the error of "Unable to load simulation case".
What I am doing to is:
File>> Import sources>>Hysys sources after that I browse the case location then press open. Each time I do this procedure, I have the same error. I am sure that both versions of Hysys and Flarenet are 7.2.
In your opinion, what is the problem source.
Thanks in advance
M Menessy
