Fluid Flow Containing Solids
#1 sanganipratik
sanganipratik
  • 11 posts
Posted 09 October 2014 - 01:37 AM
Dears,
I have a question related to fluid flow which has solids content.
I have a multiphase gas/oil/water from well, for which  pipe size needs to be calculated.
As per the reservoir data, the gas/oil/water mixture contains 4 mg/liter (80 micron size) sand and 16 mg/liter (20 micron size) sand.
What shall be the recommended velocity criteria, as AP RP 14E, does not mention the C factor for erosion case.
NORSOK P-001 specifies liquids with sand as  7 m/s but does not mention any footnote regarding the size of the sand particles and also velocity limitations for multiphase flow.
Is there a different set of equations/standards to be used while sizing considering the size of sand particles.
What shall be the C factor if erosion needs to be evaluated.
  • 6,347 posts
Posted 09 October 2014 - 01:49 AM
hi ,
You may find interesting information in this document .
Good luck.
#3 sanganipratik
sanganipratik
  • 11 posts
Posted 09 October 2014 - 02:18 AM
Thanks Breizh,
Is the manual in line with any standards, as the references does not mention so.
Also since i need to preapre a basis of design for the client, the max allowable velocity for multi phase flow needs to be refreneced and also the C factor used for erosion calculations.
The manual does not mention any of these.
Can you provide me some more information.
#4 sanganipratik
sanganipratik
  • 11 posts
Posted 09 October 2014 - 03:50 AM
And moreover Breizh, the manual states only liquid phase.
Any inputs regarding multiphase with solid content ??
#5 breizh
  • 6,347 posts
Posted 09 October 2014 - 06:10 AM
let you consider this book :
http://drbratland.com/PipeFlow2/
Edited by breizh, 09 October 2014 - 07:39 AM.
#6 sanganipratik
sanganipratik
  • 11 posts
Posted 12 November 2014 - 11:29 AM
Thanks Breizh, I shall go thru and revert.
