Hi All,
I have a drain tank to collect water and transformer oil. Minimum temperature during winter could reach -2 dgree C. However this number is only a single point, the daily minimum temp is - 0.1 dgree C. Do i need a winterizarion? If So, can i only install a heating pad at the tank bottom since water content is considered minimum.
Drain Tank Winterization
Started by Ibnu84, Oct 09 2014 04:17 AM
No replies to this topic
Posted 09 October 2014 - 04:17 AM
Sulphuric Acid H2So4 Storage TankStarted by Guest_TeeEng_* , 08 Apr 2024 |
Closed Drain SystemStarted by Guest_Falah_* , 26 Mar 2024 |
Design Criteria For Sizing Sump Drum Of Close Drain System In Tank FarStarted by Guest_AnbIran_* , 28 Feb 2024 |
Asme Code For Fiberglass Pressure Tank FeaStarted by Guest_Pheeto_* , 13 Feb 2024 |
Pressurized Deaerator Tank Exhaust Vent SizingStarted by Guest_zezima_* , 01 Feb 2024 |
