Hi, when dealing with vacuum distillation columns(50-500mbar) that just vent their overhead strem's heat to atmosphere and when thinking of possible ways to recover that heat and re-use it to improve energy efficiency, there are a couple of ways to do it. One of them is to use that heat of the top vapor stream and exchange it with say a utility stream like condensate/cooling water and generate low quality steam. This steam can be further used in the plant as such or after improving its quality. Now the problem with the idea here is, the heat exchanger or condenser at the top of the vacuum column cannot induce a large pressure drop. The heat exchange between the overheads and water must take place using a suitable exchanger/condenser design that causes low pressure drop.
Do you hve any recommendation for present day improved condenser designs for such a purpose? what type of condenser can achieve this? Something like plate condenser?the column top is around say 100-400mbar and I do not want more than 10-20% pressure drop due to the introduction of the condenser.
