Psv Required If Well Flowlines Designed For Shutin Tubing Pressure
#1 Tamizh
Tamizh
  • 21 posts
Posted 10 October 2014 - 04:56 AM
Dear all,
Does PSV required, if the well fluid flowlines are designed for shut in tubing pressure. As per API RP 14C, PSV is not required only if the design pressure is greater than shut in tubing pressure of that well, Please clarify?
Do i need to provide PSV, my design pressure of well fluid line is 250barg & well shutin tubing pressure is 250 barg? Please clarify my doubht?
#2 fallah
  • 4,950 posts
Posted 10 October 2014 - 05:48 AM
Tamizh,
I think it means PSV isn't required if design pressure of the well fluid line is greater than the pressure developed following to blocking the flow from well head i.e. "shutin tubing pressure"...
#3 cuchuoi2005
cuchuoi2005
  • 9 posts
Posted 14 October 2014 - 09:50 AM
Dear Tamizh
Can you please be a little specific on your design, whether the downstream equipment/pipings are also fully rated? If not whether they are designed with PSV for blocked outlet case? Or they are equipped with a HIPPS?
Cuchuoi
#4 Tamizh
Tamizh
  • 21 posts
Posted 31 October 2014 - 08:07 AM
Dear sir,
Sorry for the delay,
my downstream equipment is protected with blocked outlet psv, i have no problem at downstream, problem is shut in tubing pressure of well is 250 barg and my design pressure of well fluid flow lines is 250 barg, do i need to provide fire case PSV for well fluid flow lines.
as per API RP 14C psv need not be provided if well fluid line design pressure is greater than shut in tubing pressure.
Please clarify my doubht.
#5 moein_omg
moein_omg
  • 26 posts
Posted 01 November 2014 - 01:06 PM
Tamizh
I think that u have to specify possibility of a fire. If any, you have to think of a depressurizing device whether it be PSV or blow down valve (when the piping system can not tolerate relief temperature PSVs are useless making the blow down valve the remaining choice).
#6 Bhavinkumar
Bhavinkumar
  • 23 posts
Posted 02 November 2014 - 09:26 AM
It is not clear whether, flow line is have manifold at gethering station. In event of multiple wells connected with the single manifold, It is requried to also consider any possible overpressure scenario from other wells.
#7 Sathya R
Sathya R
  • 35 posts
Posted 02 November 2014 - 06:57 PM
As such margin is not provided above CITHP (SITHP) to get DP of the flow lines.
