Control Valve Location
temprature control flow control control valve
9 replies to this topic
#1 modgasman
modgasman
  • 18 posts
Posted 13 October 2014 - 04:08 PM
Hello All,
Please is there a best practice for where to  install a control valve on a cooling water loop?
Can the control valve be at the inlet of the exchanger and the temperature sensor on the outlet?
Or do they both have to be on the outlet?
Thanks in advance
#2 Bobby Strain
Posted 13 October 2014 - 06:40 PM
The best place is nowhere.
#3 breizh
  • 6,345 posts
Posted 13 October 2014 - 08:14 PM
http://www.driedger....tx/CE3_STX.html
Consider this link to support your work.
#4 modgasman
modgasman
  • 18 posts
Posted 14 October 2014 - 01:30 AM
Thanks Breizh, but the link doesn't work. I get a safety warning from my PC that it contains a lot of Malwares
#5 breizh
  • 6,345 posts
Posted 14 October 2014 - 02:50 AM
Sorry I cannot do better !
#6 fallah
  • 4,954 posts
Posted 14 October 2014 - 03:35 AM
modgasman,
The link submitted by Breizh does work without any problem. Anyway, as indicated in mentioned link, control configuration selection is to be based on the situation...
#7 Ajay S. Satpute
Ajay S. Satpute
  • 177 posts
Posted 14 October 2014 - 06:31 AM
modgasman,
File downloaded from Breizh's link and attached herewith.
Regards.
Ajay S. Satpute
#8 modgasman
modgasman
  • 18 posts
Posted 14 October 2014 - 03:00 PM
Thanks all for your contribution, I appreciate it
#9 Bobby Strain
Posted 14 October 2014 - 04:00 PM
Take note that this paper talks about heating medium, not cooling water. If you throttle cooling water you risk fouling the exchanger. Unless you are using some closed loop system that is properly treated. And, perhaps, contains glycol.
#10 fallah
  • 4,954 posts
Posted 15 October 2014 - 01:42 AM
Bobby,
Throttling the cooling water supply at user (here an exchanger) battery limit to adjust the cooling rate is a normal practice in all industries; to avoid fouling it's adequate the water would have proper quality and/or the outlet water temperature to be not so high...
