In our MDEA sweetening units, we are using Plate Heat Exchangers to preheat Amine Regenerator feed. In 6 units out of 9 we have two PHE's per unit to cater to the full heat load. While in rest 3 units we have only one PHE for the total heat load. We are experiencing problem of unequal distribution of flow in split PHE's & these PHE's leak frequently. While single PHE's are working fine & leaks rarely. We are planning to replace 3 units PHE's out of 6 of split flow PHE's & in dilemma whether to go for the same split flow PHE's or the full flow PHE's. For changing the philosophy of split to full flow PHE, we need to convince our management by some solid reasoning. Is there any strong technical reason to install full flow PHE?
Split Flow Phe Vs Full Flow Phe
Started by apex, Oct 17 2014 09:02 PM
No replies to this topic
Posted 17 October 2014 - 09:02 PM
Flow Switch High RangeStarted by Guest_Lyne_* , 11 Apr 2024 |
Kettle Reboiler Flow FractionsStarted by Guest_Lyne_* , 31 Mar 2024 |
Mtbe Process Flow Diagram Master Thesis.Started by Guest_sayoub_* , 15 Feb 2024 |
Duplication Of Psv And Flow Rate For Exchanger Tube Rupture ScenarioStarted by Guest_Platonicus_* , 11 Mar 2024 |
Firewater Theoretical Vs Actual FlowStarted by Guest_stu_* , 25 Feb 2024 |
