Pump Min Flow And End Of Curve Design
Started by m42364236k, Oct 20 2014 10:06 AM
Posted 20 October 2014 - 10:06 AM
Dear friends i
I have 2qiestion about the pumps
1-about minimum flow line
For intermittent pump dose it need to consider the min flow.line or not ?
In.our.plant we have two 40kw pump.both work 4 hours per day the designet has not been considered for this pumps min flow line .
Does it need ?
Second question is about pump end of curve.
One.pump.in.our.plany design in end.of curve operation.
I want to see in the data sheet of pump for confirmation .dose it have any place in data sheet to shoe us this pump motot design for end of curve ?
Does it need ?
Posted 20 October 2014 - 12:21 PM
1- Normally even an intermittent pump with mentioned power needs minimum flow line if discharge blockage would be a credible scenario.
2- If the pump had been designed for end of curve condition, it is reflected in relevant D/S...
Posted 20 October 2014 - 01:51 PM
What type of pump are you talking about? Centrifugal? Positive Displacement?
Jt Based Hcdp Design V/s Mechanical Refrigeration Hcdp Unit.Started by Guest_BabRafiq1_* , Today, 01:43 AM |
Heavy Crude PumpStarted by Guest_Rahimzadeh_* , 13 Apr 2024 |
Rupture Disc DesignStarted by Guest_chaupradip_* , 13 Apr 2024 |
Flow Switch High RangeStarted by Guest_Lyne_* , 11 Apr 2024 |
Pump Sizing ConsiderationsStarted by Guest_panagiotis_* , 07 Apr 2024 |
