Hi
In our project we are dealing with 3phase PSV. PSV outlet is routed to atmosphere without any flare. PSV is conventional type. PSV set pressure is 100 barg.
We have sized the PSV based on rated flow and 18" outlet size is calculated with 0.9 mach and back pressure of 2.5 barg.
Client is asking to reduce the outlet size by putting a reducer or restriction orifice at the end of the pipe. By that they are looking to choke flow at the outlet of piping and creating more back pressure at the PSV outlet. Client's argument is for flare tip you will get 1.0 mach. Comparing with flare they want to design our system with 1.0 mach at the outlet.
My question,
1. Is this acceptable to put a reducer or orifice at the end of open pipe. I could not find any direction in API which says it is not acceptable.
2. Will this work for 3 phase flow? I have never this sort of arrangement in tail pipe.
regards
ak
