This is not to be confused with any fuel efficiency monitoring system?
It doesn't seem so from your explanation but I thought it best to check.
in medium and high speed diesesl the usual oerating profile can include a lot of variable conditions from idle to full power. A simple flow on demand to the engine would result in a very wide flow rate range but usually such installations use a fixed flwo rate supply with a return of unsude fuel to the tank.
In diesel fuel systems, flow to the engine from the tank is usually supplied at twice the maximum consumption rate and the unused fuel returned to the tank thus varies from half the supply flow upto the maximum suply flow so the flow rate ratio of flow to and flow return is thus in the range 2:1.
It is usual in such systems to have a flow meter in both the flow and return lines and use a diferential totaliser for consumption monitoring. There are a variety of systems available which correlate the fuel consumption with engine speed, GPS data etc to determine the optimum fuel efficiency conditions.
On the other hand, while the same 2:1 flow principle is used for heavy fuel oil engines, the fule is circulated locally in a high pressure loop with fuel from the tank introduced via the mixing tank in the high rpessure circuit. In these systems there is usually only one flowmeter in the make up line. This is adequate because low speed diesels generally spend substantial proprotion of their operation at one speed, or wth only minor variations in speed such as in marine propulsion applications.
But as I say, it doesn't seem from your description that this is part of the consumption system and it is only for the medium and high speed engines I would expect to see a flow meter in any flow line to the tank without another in ths supply from the tank to the engine.
On the other hand, if the fuel layout is such that tank filling takes place via the return line from the engine to the fuel tank, and the filling point is upstream of the return fuel flow meter it could be a way of making use of the return flow fuel consumption meter to monitor fuel loading.
Is the fuel system such that the return from the engine to the tank is seperate from the tank filling operation?
This is a bit of a reach because I would expect the flow rates filling the tank to be far higher than the flow rates in the consumption monitoring meters.
Edited by JMW, 12 November 2014 - 06:40 AM.
