Hi, I'm a Chemical Engineering student and I have a question about the design of a packed bed tubular reactor for heterogeneous catalysis on steady-state. I'm using Matlab to solve the one-dimensional model with axial dispersion:
Where CAb is concentration, z is the length of the packed bed, DAB is the dispersion, U is superficial velocity, rA is the reaction rate and rhob is the packed bed density.
I've been working on this a lot but I can't find the problem. Heres is the Matlab code just if you can help me.
clear all; clc %butanotiol+heptano %T=25ºC Deff=0.046E-8 %m2/s ro_b=167.9400; %kg/m3 L=4.27; %m U=0.0024/0.327; %m/s k=4.68E-2 %m6/(mol*s*kg_cat) Ca0=6.05; %mol/m3 %ODE z=0:0.000001:L; z1=z'; y0=[Ca0; 0] ode_react = @(z,y)react(z,y,U,Deff,ro_b,k); [z,y]=ode15s(ode_react,z1,y0) plot(z,y(:,1)) ylabel('Concentración Ca [mol/m3]') xlabel('z [m]')
function
function dy=react(z,y,U,Deff,ro_b,k) dy = zeros(2,1); dy(1)=y(2); dy(2)=(U./Deff).*y(2)-k.*ro_b.*(y(1).^2)./Deff; end
Thanks for everything.
