Differential Pressure Across Prereformer
10 replies to this topic
#1 kamranarif
kamranarif
  • 7 posts
Posted 30 October 2014 - 02:30 AM
We have observed exponential rise in pre reformer (at ammonia plant) pressure drop within 10 days. It may me noted that it is gradually increasing daily. As of now it has been increased from 0.4 to 2 kg/cm2.
Detailed analysis revealed no change in catalyst activity and its performance is consistent
Please share your experiences on the same
#2 PingPong
PingPong
  • 1,446 posts
Posted 30 October 2014 - 05:30 AM
I would guess that catalyst bed fouling is the most likely cause.
Due to a change in the composition of the feedstock (such as more heavies and/or aromatics, or more ...... other contaminents).
#3 kamranarif
kamranarif
  • 7 posts
Posted 30 October 2014 - 05:56 AM
Thanks for your response. Would not this also effect the upstream reactors i-e NiMo/ CoMo bed and ZnO bed. It may be noted that no change has been observed in these reactors
#4 PingPong
PingPong
  • 1,446 posts
Posted 30 October 2014 - 07:22 AM
Prereformer operates at much higher temperature than HDS and ZnO.
You should compare the compostions of the original design feedstock, the feedstock before the pressure drop increase, and the feedstock during the pressure drop increase..
#5 kamranarif
kamranarif
  • 7 posts
Posted 30 October 2014 - 08:30 AM
Please note that no detectable change in gas quality has been observed. You are requested share any relevant literature, that would be beneficial in trouble shooting.
Thanks and regards
#6 rychurek
rychurek
  • 45 posts
Posted 01 November 2014 - 05:05 AM
Does streams flow rates( steam, recycle hydrogen and hydrocarbons ) are unchanged? Check pressure drop across reformer too.
#7 kamranarif
kamranarif
  • 7 posts
Posted 01 November 2014 - 06:38 AM
Pressure drop Primary reformer is normal. Streams flow rates have been counter verified and are within design limits.
Thanks rychurek
#8 kamranarif
kamranarif
  • 7 posts
Posted 01 November 2014 - 06:43 AM
New development:
We decided to bypass the pre-reformer to check its behavior. After the activity (~2.0 hrs) the pressure drop across pre-reformer reduced from 2.0kg/cm2 to 0.8kg/cm2,. However, it has started increasing again.
Edited by kamranarif, 01 November 2014 - 06:45 AM.
#9 PingPong
PingPong
  • 1,446 posts
Posted 01 November 2014 - 10:22 AM
Could be that the bed expanded a little while being bypassed, resulting in an increase in void fraction, and therefor a decrease in pressure drop. But during renewed operation the bed starts to compact again, void fraction decreases, and pressure drop increases again.
#10 rychurek
rychurek
  • 45 posts
Posted 01 November 2014 - 01:38 PM
Are you sure that dp. measurement indication is correct? Is prereformer upstream pressure increase when prereformer dp. Is going up?
#11 mehdi
mehdi
  • 18 posts
Posted 09 November 2014 - 10:00 AM
hi dear kamranharif
2 bar delta p is very high that means mor than 70% of catalysy chang to powder
i'm work in ammonia plant but we have not pre reformer so please show me general drawing of your pre reformer
maybe you have blocking in inlet our outlet of device inside of reactor
thanks
M.M.A
