Blowdown Simulation With Prode
volume enthalpy pressure flash operation prode blowdown simulation
#1 mrbabu
mrbabu
  • 55 posts
Posted 04 November 2014 - 04:30 AM
to simulate a blowdown with Prode Properties (in case the standard procedure is not applicable)
is it better to adopt V-H or V-P flash specifications ?
the Volume-Enthalpy specification should allow a more accurate solution of energy balance, is it true ?
I have a vessel with liquid vaporizing (fire case) and I wish to define my own models for RO and piping,
does that make sense from a practical point of view ?
#2 marchem
marchem
  • 153 posts
Posted 04 November 2014 - 07:35 AM
the V-H flash solves directly for temperature and pressure given volume and enthalpy,
you can obtain a somewhat equivalent result by dividing dP in several steps and
solving a series of V-P flash operations, from that point of view it is preferable to solve
a series of V-H flash operations.
However I would caution that many values (an example, heat from fire)
are usually estimated (with maybe large errors) and any procedure *can't be* very accurate...
For the same reasons it doesn't make much sense (in my opinion)
the claims of superiority of a procedure against another,
a critical review of calculated values in most cases is required....
see also the comments in previous threads discussing blowdown...
#3 serra
serra
  • 310 posts
Posted 20 November 2014 - 02:28 AM
"the Volume-Enthalpy specification should allow a more accurate solution of energy balance, is it true ?"
I agree with marchem, in some cases you may find a equivalent numerical solution with different flash operations,
of course in Excel it is easier to call a simgle macro in Prode Properties which does all the work
instead to have many lines of code running slow...
#4 mrbabu
mrbabu
  • 55 posts
Posted 18 December 2014 - 07:54 AM
thanks marchem & serra,
to estimate the heat absorbed in fire I adopt the API correlation,
do you consider that procedure accurate ?
#5 marchem
marchem
  • 153 posts
Posted 18 December 2014 - 11:03 AM
it's a standard, difficult to say how reliable are the values predicted,
anyway most engineers do use those values...
for a detailed discussion about the models see the M.A. Wong thesis "Development of a mathematical model for blowdown of vessels containing multi-component hydrocarbon mixtures",
if you plan to write your own procedure that may help you a lot.
#6 mrbabu
mrbabu
  • 55 posts
Posted 23 December 2014 - 11:05 AM
thanks,
it seems they did specific tests for estimating  the heat absorbed in fire,
instead  to adopt the methods proposed in standards (for example, API).
#7 marchem
marchem
  • 153 posts
Posted 05 February 2015 - 08:10 AM
right,
the main advantage of adopting a standard is that you are not required to provide a proof that results are correct :-)
Really, simulating a blowdown is a complex matter,
most engineers do utilize some software but with little control over the many different parameters ,
as result it is difficult to guess how accurate the results are...
