The client requires a steam heater(a plate HX) for non continuous use. When production needs, the steam is on and the process fluid is on. When it is not needed, the steam and process fluid are turned off.
I don't have much experience on this kind of on/off process. I am really doubting, if a steam heated plate heat exchanger can be used in this way. If yes, are there any special design requirements? And how long it takes to heat up process fluid to the target temperature (or how to calculate how long it takes)
Thanks.
