Hi friends,
Case: I have a gas swivel seal leak line of 3/4" which is connected to the LP flare header and the pipe line is fitted with an orifce and downstream to orifice is a flowmeter.
Under normal operation there shouldnt be any leaks and if there is it should be very minor @acceptable range.
If the seal fails, then the line see a an upstream gas pressure of 170 barg, which is the gas swivel operating pressure. An orfice is selected, inorder to safe guard the downstream LP header which operates at 1.5 barg.
Now the question is the significance of the choke flow/ crtical pressue. As obviously i see that under leakage condition the orifice sees a choked flow @ 97 barg critical pressure. So should I design my downstream piping and the flowmeter for pressure of 97 barg or 1.5 barg.
Your suggestion is appreciated.
Pratik
