Estimating Gas Velocity
#1 Aneken
Aneken
  • 22 posts
Posted 14 November 2014 - 01:19 AM
Hi All
For a project, i am dealing with a gas which is entrained with solid particles. The flow rate of the gas is 500 kg/hr. Density of solid laden gas is around 5 Kg/m3(say) at operating temperature and pressure.
I want to do a prliminary estimate of the separator vessel's diameter.
I am thinking of applying the following methodology for the same:
Volumetric flow rate = Area x Velocity
Is the above methodology correct?
If yes, than what should be the velocity of the gas  ?
Should it be the same as the velocity , i have used to determine pipe size which is around 15 m/sec(assumed).??
Is there any relation to determine velocity like we have Souder's-Brown equation for Vapor-liquid separation.??
Thanks in advance.
  • 6,347 posts
Posted 14 November 2014 - 05:52 AM
Hi Aneken ,
Let you consider technology like Cyclone or Filtration , the PSD of the solid is an important factor for the selection of the equipment .
Consider Google to support your work.
My 2 cents
#3 Aneken
Aneken
  • 22 posts
Posted 15 November 2014 - 02:30 AM
Hi Aneken ,
My 2 cents
Thanks for your reply Breizh.
I dont have any Particle Size distribution data (PSD) with me.
Moreover , i want to just estimate the size.(size estimate only).
So it would be a great help if you could let me know if the methodolgy adopted by me is right or not.?
Also these questions are baffling me
I would really appreciate your help in this regard.
#4 breizh
  • 6,347 posts
Posted 15 November 2014 - 03:56 AM
Aneken ,
To get an effective separation you need
1) to drop the velocity significantly .
2 ) to force a change of the direction of the gas flow which will facilitate the separation gas/solid ,
3  to add a baffle or inverse cone to prevent the carry over of solid .
notes : *Perry's chemical handbook should  help you , check solid/gas separation .
additional resource
http://books.google....ulation&f=false
Good luck.
Edited by breizh, 15 November 2014 - 05:18 AM.
