Control System For Positive Displacment Type Pump
#1 m42364236k
m42364236k
  • 94 posts
Posted 19 November 2014 - 09:41 AM
Dear friends
i see on P&ID after the plunger type pump they use the PCV(regulator valve)
as i know this type of pump is positive displacement work not centrifugal type.
can we use the control valve after positive displacement pump for controlling the pressure ?
thanks
mike
#2 latexman
  • 1,688 posts
Posted 19 November 2014 - 10:46 AM
It really depends on the P&ID and what type of regulator valve it is.  If you attached the P&ID and gave some details on the regulator valve (pressure regulator or back-pressure regulator), we could help some more.
Edited by latexman, 19 November 2014 - 10:46 AM.
#3 hianbotech
hianbotech
  • 24 posts
Posted 19 November 2014 - 11:43 AM
Provide more information about your system to understand the requirements.
as a general information, a self regulated valve is typically installed in the discharge of the positive displacement pumps "chemical injection skids' to keep a constant back pressure at the discharge of the pumps.
#4 samayaraj
samayaraj
  • 239 posts
Posted 19 November 2014 - 11:45 PM
Mike,
In general, PD pumps do not have control systems. To maintain a constant discharge pressure, a manual pressure control valve/ self regulated pressure control valve will be provided.
#Samayaraj
#5 breizh
  • 6,347 posts
Posted 20 November 2014 - 12:41 AM
http://modelingandco...nt-pump-part-2/
http://modelingandco...nt-pump-part-1/
mike,
Take a look at these links  , it should help you .
Good luck.
Edited by breizh, 20 November 2014 - 12:43 AM.
