Hi Friends,
I have to evaluate the Desalters manufcaturing data/mass balance provided in its offer.
I calculated the required dilution water, but it turns out to be only 20% of what is given by the supplier.
The supplier has given two values for dilution water flowrate considring Crude oil of API 16 & API 14.
1. Does different API result in different values of dilution water flowrate, kindly explain.
2. Can someone pls provide me with the solution/spreadsheet to calculate the dilution water flowrate & other paramters for Two stage desalter.
3. The parameter are listed below:-
Dry Crude Flowrate - 104.9 cu.m per hr
Water content - 25% (v/v)
Salt content in water/feed - 153000 mg/l
Mixing Efficiency for each stage is 60% (as per supplier)
Water content at outlet of 1 & 2 stage is 0.5% (v/v)
Salt content in dilution water - 500 mg/l
Max PTB at crude outlet for API- 14 is 44 & API - 16 is 50
API - 14 density - 888.1 kg/m3, visc -21 cP & API-16 desnity - 906.3 kg/m3, visc - 29.6 cP
Thanks in advance.
