Hi everyone, thank you for taking time to read this message. I am trying to look for a flow meter with +/- 0.5% accuracy for the following application:
- Process fluid: methanol
- Flow: continous at 0.011 - 0.064 m3/h
- Pressure: op 1042 kPag max 1379 kPag
- Temp: 10 deg C
- Line size: 1/2" tubing
Vendor suggested a Coriolis meter. I understand Coriolis provide good accuracy at low flow rates but it is also quite expensive. I've narrowed down to couple other flow meter options:
- Flow nozzle
- Segmental wedge
- Rotary piston (+ve displacement)
Does anyone have experience in using these flowmeters for similar application? If so, what range of accuracy, pressure drop, calibrated range and flow velocities am I looking at? Feel free to suggest other flow meter types. Thanks!
