What is thew use of balancing ling in the pig Launcher and Receiver?
Pig Launcher Receiver
Posted 04 December 2014 - 07:29 AM
Posted 04 December 2014 - 11:50 AM
Pig launcher/receiver is isolated from the normal operation. The pressure inside the barrel of pig launcher/receiver is 0 psig during the normal operation. When you are ready for switching to a pigging operation, you should pressurize the pig launcher/receiver to 'balance' the pipeline pressure and barrel pressure before opening the pigging valve to introduce the pipeline fluid into the pig launcher/receiver barrel.
Posted 04 December 2014 - 08:24 PM
Tamizh,
Consider reading these papers. Safety/operation are key .
Hope this will help you out.
Posted 05 December 2014 - 03:15 AM
With regards to this topic, does anyone have any experience to share with regards to flowmeters which allow pigging?
I am considering using a full bore type so that the pig may pass through with no problems. Then there will be no need to remove the flowmeter during pigging operation.
Posted 05 December 2014 - 07:40 PM
You can use an external ultrasonic meter.
Air Receiver SizingStarted by Guest_panagiotis_* , 01 Mar 2022 |
Sizing For Psv Located On A Pig ReceiverStarted by Guest_Danish John Paul_* , 19 Feb 2021 |
Requirement Of Psv On Air ReceiverStarted by Guest_Yogesh Bhatt_* , 11 Feb 2019 |
Answered
Maximum Pressure Build Up In A Receiver VesselStarted by Guest_raman123_* , 24 Jan 2018 |
De-Ethanizer Receiver Relief Load CalculationStarted by Guest_go-fish_* , 03 Jan 2018 |
