Dear All Professionals:
I have a doubt on sizing PSV for shell and tube heat exchanger.
Here are the process information:
Tube side fluid: process liquid
Tube side pressure: operating at 30barg and designed at 40barg
Tube side temperature: 93-95 degC
Tube side fluid boiling point: 102 - 104 degC at ATM
Tube side has a control valve (fail open) at cooling water return line
Shell side fluid: cooling water
Shell side pressure: operating at ~3barg and designed at 6barg
Based the pressure ratios, i should consider tube rupture case for this heat exchanger.
Also, sometimes the cooling water temperature goes up to 80degC when cooling load is small. Considering cooling water has some chlorine content and it could be corrosive over the time.
Now I have several questions:
1. Is a PSV really required considering the cooling water supply line is always open?
2. When I calculate the relief capacity, shall I consider the cooling water supply line also a pressure relief point? Because the current DP between tube and shell side gives a super large liquid flow through the tube (28mm ID)
I am really confused and hope i could get some tips here.
Thanks.
