Hi
First of all I would like to thanks all of you for attention and sincere help. I have to design a reactor in which tri-pentyl-ammonium-butyrate is decomposed into butyric acid and tri-pentyl-amine. The boiling point of butyric acid at atmospheric pressure is 163 oC. In this reactor vacuum is generated to decrease the boiling point to 90 oC. I have also attached a pfd of this process.
The vapours of butyric acid go into a condenser at the top and tri- pentyle-amine is separated from bottom. My question is can we take the condenser temperature 85 degree c? because in the next step butyric acid need to be heated again.second what would be the change in temperature when butyric acid is shifted from vacuum to atmospheric pressure. Third how butyric acid can be transferred from vacuum to atmospheric pressure. Please reply. I would be very Thankful to u all.
condensor pfd.docx 220.42KB 14 downloads
