Suppose there is a vessel with a fixed volume of 2000 cubic metres. A fuel gas is generated at the rate of 50000 kg/h which enters the vessel and is consumed at the same rate, i.e., 50000 kg/h. A pressure of 4 kg/cm^2 is maintained in the vessel. The fuel goes to the flare if the pressure in the vessel exceeds 4.25 kg/cm^2. Now, if the generation rate of the fuel increases to 57000 kg/h, keeping the consumption rate unchanged (50000 kg/h), by how much should the fixed volume of the vessel increased so that the fuel does not go to the flare (i.e., keeping the vessel pressure below 4.25 kg/cm^2). The density of the fuel is 0.8 kg/m^3. Calculations are to be done for 1 hour.
Thanks in advance.
Edited by tanvisinha, 17 December 2014 - 11:40 PM.
