If I have compressor , the material inside made of stainless steel while the material outside made of carbon steel .. Is there a method for estimate the cost ?
The compressor have five stages , the power of each stage around 3800 kW
I use the following equation for estimating cost :
Total purchase cost = drive factor x material factor x compressor price .
Drive factor = 1 for electric motor drive , 1.15 for steam turbine and 1.25 for gas turbine
Material factor : 1 for carbon steel , 2.5 stainless steel and 5 for nickel .
The problem is in the material , what should I consider for material factor in my case ??
Cost Of Compressor
Started by SadiqChemy, Dec 19 2014 07:35 AM
Co2 Removal Membranes Between Compressor StagesStarted by Guest_Sinclc_* , 26 Mar 2024 |
Answered
Centrifugal Compressor Performance Curves In Aspen HysesStarted by Guest_Rafcio_* , 14 Mar 2024 |
Design Gauge Pressure Inlet To A Centrifugal Compressor.Started by Guest_Mohammad3799_* , 03 Mar 2024 |
Gas CompressorStarted by Guest_Md Ziaul Islam_* , 23 Jan 2024 |
Settle Out Pressure For Reciprocating CompressorStarted by Guest_prashant.badgujar_* , 03 Jan 2024 |
