Dear all,
I am designing (sizing) a PRV for a PIG Launching System placed in the discharge line of Positive Displacement pump (note that I am a junior and that I am doing this for the first time). The liquid is Crude Oil (16 deg API). The valve manufacturer sent a list of required information regarding the system in order to select an appropriate valve. However, I am not sure about some of the requirements. Some elaboration on the following topics would be much appreciated:
- First of all, the "Set Pressure" for the PRV is to be specified. Seeing as PD pumps have an "infinite shut-off pressure", to me it seemed correct to specify the set pressure as: Max. allowable line pressure (200 psi) minus % Allowable overpressure (10%); this equals 180 psi. Am I correct in doing so?
- Secondly, the Relieving Temperature is required. I have absolutely no idea on how to specify this; are there any guidelines/suggestions on how to do this?
- The Required Reliving Capacity is just the nominal operating capacity or is it the pump capacity at the max. allowable pressure?
See the attachment for the PFD of the system.
Any comment/clarification will be much appreciated.
Thanks in advance.
