Presently i have to find out relief rate for a PSV located in expansion tank in concntrated solar power plant.
Expansion tank is used to store thermic fluid.
I am attaching one rough sketch showing all inlet and outlet streams on expansion tank.
We generally try to maintain 9.65 barg pressure in the expansion tank with nirogen blanketing.If the pressure in vapour space of expansion tank exceeds 9.65 barg pressure vapour will be vented out to primary condenser.
Bottom part of expansion tank is lacated at 10 m height above ground.
I do not understand which case will be suitable to find out relief rate for PSV.
Please help me.
