normally you see water in liquid (and vapor) phases in different sections of the plant,
you can estimate the amount solving phase equilibria,
at constant temperature for a stream of hydrocarbons + water if you increase pressure,
within certain limits the amount of water contained in the vapor phase increases (due to higher density of vapor phase),
note that in most cases with hydrocarbons water forms a separate liquid phase,
for accurate results you need to model accurately the fugacity of water,
as said make sure to select a suitable thermo package.
