Dear All, please I very need your help
I tried to simulate crude Oil with 2 different spec. first a crude oil based on design spec, and the second is crude oil from Banyu Urip Well (Indonesia) that will used as actual feed for my plant.
The point is, this refinery wants to compare the product result between crude oil design with crude oil actual.
I have tried to simulate the crude design with refluxed absorber column and have a good result, column converged. I input all operations parameter that state on their engineering document such a temperature, capacity, flow kerosine, diesel, residue, pressure, plate number, etc..all this parameter already determined by them. so far I use this parameter to simulate with crude design, there is no problem appear.
But, the problems appear when I use the second crude oil from Banyu Urip. I have input TBP data, bulk properties data and density data. and the result, hysys show that this crude have a different composition with the design crude. I see that kerosine naphta and diesel already change and has turn into fewer.
When I tried to run the column with the simmiliar spec parameter that I used before, the column is not converged. I see on monitor window, that flow of kerosine from kerosine stripper is increase of error. this error occur because there is a considerable difference between a value estimate that I input and actual value that calculated by HYSYS. I wait until 2000 iteration and column did not converged well. And matrix diagonal zero appear.
I attach the HYSYS file. the design simulation and the actual simulation.
I wish there is HYSYS expertist in this Forum who wants help me. or anyone who has a simmilar problem with me and has found the solutions.
download link file
http://www.4shared.c...HYSYS_file.html
sorry I am not permitted to upload hysys file in this website.
Muhammad RIzal
Jakarta, Indonesia
