I am studying deisobutaniser column in alkylation unit of a refinery. As I looked at the column bottom configuration / temperature profile in the documents the situation looked unusual, Following are my observations / queries.
1. Column bottom is baffled.
2. The liquid from the bottom tray is at around 160 deg C.
3. The reboiler outlet is at 186.3 deg C.
4. Reboiler inlet is at 173 deg C.
5. Bottom product is at 186.3 deg C.
The column bottom configuration is given in the attachment.
My queries are as follows
1. Query 01:
That even though the bottom product and reboiler outlet is at same temperature the composition of the reboiler outlet liquid and the bottom product is not same as per the H&MB document. How is this possible?.
1. Query 02:
After a long run the temperature of the bottom should come to saturation and bottom product and reboiler inlet should be at same temperature, but the H&MB shows different temperatures as mentioned above.
