As we know gas specific gravity is the ration between gas molecular weight and air molecular weight (29)
This is only partially true. Specific gravity is defined as the ratio of two densities: the density of the fluid divided by the density of a reference fluid (almost always air for gases). You should be able to show that, if we assume that our gases are ideal, that the ratio of the densities reduces to the ratio of the molecular weights. If you have forgotten or have never done this derivation, you should perform the derivation to convince yourself that it is true.
So, your specific gravity=MW/MW(air) is true, if we are assuming that our fluids and air are ideal gases. The question behind your question is, "can you assume that your test fluid and air are both ideal gases?"
