Vacuum Distillation Column
vacuum distillation
#1 Donna
Donna
  • 3 posts
Posted 09 February 2015 - 08:00 AM
Hello everybody,
I am currently studying chemical engineering and have to design a vacuum distillation column. The process is actually quite simple: a solution of water with hydrogen peroxide enters the vacuum distillation column to produce a 50:50% water and hydrogen peroxide solution. The aim is to remove water from the feed, which leaves from the top .
Does anyone know the procedure for designing such a vacuum distillation column?
Thanks!
#2 thorium90
thorium90
  • 1,073 posts
Posted 13 March 2015 - 12:40 PM
Its just another distillation column at a different pressure. Mccabe thiele method should work fine.
#3 curious_cat
curious_cat
  • 475 posts
Posted 05 April 2015 - 02:41 AM
The challenge in real H2O2 columns is avoiding decomposition. That can be quite dangerous.
