Depressuring Natural Gas Pipeline With Prode
Posted 21 February 2015 - 07:17 AM
Posted 21 February 2015 - 09:11 AM
by design RO works at critical condition, hydrates and ice should form after RO,
if there is some large space immediately after RO (for example a separator) formation of solid phase may have a limited impact
and you could (manually) stop depressuring to allow hydrates to dissociate (providing heat etc.),
instead, if there is some small piping (for example to a flare), you should consider the possibility to have a plug and pressure rising to pipeline pressure....
About inhibitors, different companies adopt different procedures and it is difficult to suggest a rule, for example consider that MeOH is much more toxic than MEG but there could be several reasons to prefer different methods or different products...
About water content in natural gas I would stay with ISO 18453 which gives certified values (within its range of application),
for water contents the ISO 18453, extended Peng Robinson and GERG models available in Prode Properties give similar results.
I have not access to the paper "The Effect of Ethylene Glycol or Methanol on Hydrate Formation in Systems Containing Ethane..." and I can't comment,
however similar methods are discussed in books such as Clathrate Hydrates of Natural Gas (Sloan) or Natural Gas Hydrates (Carrol).
Finally, I can observe 30-60% (and in some cases higher) differences in amount of inhibitors calculated with different methods,
may be someone will claim that he can estimate the exact values but in practice I never (except by chance) observed that accuracy.
Posted 25 February 2015 - 12:10 PM
Posted 25 February 2015 - 02:01 PM
sure heat tracing could be a solution,
however to be effective you need to keep pipe wall at a temperature above hydrate formation,
installed power will depend from fluid flow, properties etc. etc.
there are correlations in literature or you may ask the supplier...
Posted 20 March 2015 - 10:53 AM
thanks,
following your advice I have estimated the power (W / m) required to avoid hydrate formation,
given gas flow, temperature, density, thermal conductivity etc. I have calculated the heat required per mt of pipe to maintain the pipe at temperatures above hydrate formation,
the value is more than two times the value proposed by a manufacturer...
Posted 06 April 2015 - 01:12 AM
those differences (your calc's and manufacturer selection) do not seem too unusual to me for heat tracing,
unless you specify exactly the amount of power required manufacturers will apply their own methods which may give different results.
Piping Design_ Pump PipelineStarted by Guest_anh.phungthai@boydensvn_* , 29 Feb 2024 |
Conversion Of M3 Of Natural Gas To M3 Of LngStarted by Guest_sachico28_* , 30 Sep 2023 |
Increasing Raw Natural Gas Dew PointStarted by Guest_lowrentstuff_* , 18 Sep 2023 |
Purpose Of Natural Gas Saturator?Started by Guest_daraj_* , 06 Aug 2023 |
Natural Gas Wells Location And Production Volume DataStarted by Guest_ChinmoyBasak_* , 08 Feb 2023 |
