I am doing psv sizing for fire case wetted wall for three phase separator. In this case i need to consider adjacent piping volume for calculating the exposed surface area of the vessel.i.e exposed surface area of the vessel can be calculated based on the liquid level high-high and the adjacent piping volume. How to calculate the adjacent piping volume? Pls explain.
Posted 23 February 2015 - 06:03 AM
Posted 23 February 2015 - 10:35 AM
You can calculate the surface area within the exposed section for piping based on the layout and dimensions. Or as a thumb rule, you can consider 10% extra on the wetted surface area of your vessel for the associated piping and fittings.
Posted 23 February 2015 - 11:59 AM
As Ahmadikh mentioned, you can consider 10%-15% additional wetted area to account for pipework...
Pump Sizing ConsiderationsStarted by Guest_panagiotis_* , 07 Apr 2024 |
Barometric Legs Line SizingStarted by Guest_panagiotis_* , 17 Mar 2023 |
Sizing Of Vertical/horizontal Flash DrumStarted by Guest_Mohammad3799_* , 10 Mar 2024 |
Design Criteria For Sizing Sump Drum Of Close Drain System In Tank FarStarted by Guest_AnbIran_* , 28 Feb 2024 |
Ro SizingStarted by Guest_T_bag_* , 27 Feb 2024 |
