Hello friends ;
I'm wondering if anyone know the difference between a distillation column and a column subflowsheet in hysys ?
and in what cases we should use them ?
Thanks a lot
Regards !
Posted 06 March 2015 - 08:24 AM
Hello friends ;
Thanks a lot
Regards !
Posted 06 March 2015 - 11:39 PM
A subflowsheet is good to use for portability. You can save it as a template and import it into other simulations. I don't think the normal column subflowsheet has this portability. But you can test it to confirm.
Posted 07 March 2015 - 03:35 AM
Bobby is correct. Sub-flowsheets are normally used when there is a need for modularized approach in simulation, which usually occurs in few cases:
- Simulation case is extremely complex and consists of several different processing units. It makes sense to split them in several dedicated sub-flowsheets (see e.g. Hysys sample file for LNG). This also makes it easier for the user to monitor changes inside the processing blocks, by simply clicking on the related flowsheet rather than drifting through a single main flowsheet and looking for the streams/equipment of interest.
- A sub-flowsheet can easily be added from the main simulation case to another simulation case, simply by extracting (copying) the template and pasting it in another flowsheet. Also, if for any reasons, you want to evaluate performance of your design without certain equipment module/unit, you can simply remove the unit in a single step.
Posted 09 March 2015 - 04:23 AM
hello all ;
I think you are not understunding my topic the column subflowsheet is located at flowsheet , then add operation then sub-flowsheets then column-subflowsheet , my problem is how to add tray number?
I'm wondering if anyone could guide me ?
Regards !
Posted 09 March 2015 - 12:52 PM
I think none of us understands what are you saying because it is hard to follow without a scheme. Whether the column is in the main flowsheet or in the sub-flowsheet, double-clicking on the column opens the related window where you can define number of trays, inlet/outlet streams, and operating conditions.
Posted 21 March 2015 - 02:41 PM
Hello friends ;
Thanks a lot
Regards !
Hi, If I am correct, with this option you can modify the column and could replicate as is. You can modify column such as bottom sump with partition plate, thermosyphon reboiler, heat pump arrangement etc. Please let me know any additional info you may need.
Posted 25 March 2015 - 11:39 PM
Dear all ;
The example I'm seeing is the Hysys sample file for modeling a crude vacuum system with preheat train
If I'm true they have used prebuilt columns located at flowsheet then add operation
Diked Area Around Distillation ColumnStarted by Guest_hysyshunter_* , 15 Apr 2024 |
Distillation Column Decommissioning ChecklistStarted by Guest_m.bhut_* , 08 Apr 2024 |
How To Find K-Values Of A Hydrocarbon Mixture On Aspen Hysys?Started by Guest_Alexis Azamar_* , 08 Apr 2024 |
Extension Reaction Kinetic In HysysStarted by Guest_Ulbert Zsolt_* , 29 Mar 2024 |
Aspen Custom Model Won't Load Into HysysStarted by Guest_SaintLazarus_* , 21 Mar 2024 |
