Problem With Modeling Actual Heat Exchanger
Started by Faraam026, Mar 06 2015 11:14 AM
modeling heat exchanger
Posted 06 March 2015 - 11:14 AM
I have to simulate a flow/heat transfer loop. The problem is that, for the heat exchanger I have only initial rated pressure drop/flow values. Many of tubes have now been plugged along with other adverse changes. How can I put this actual heat exchanger in my simulations? What calculations/measurements I will be required to do on the heat exchanger?
Posted 06 March 2015 - 12:10 PM
Do you have the bundle information such as the tube layout and baffle data ?
Posted 06 March 2015 - 01:08 PM
Baffle dimensions and other data is available to us. Number of plugged tubes is also known. What we do not know is the extent of clogging on tube side------- circuit that is to be modeled.
On shell side we have temp., dp and flow instruments.
Posted 06 March 2015 - 06:03 PM
First thing to do is to use the shell side instruments and measure the flow and inlet and outlet temperatures. From this information you can calculate the heat load.
Time Required To Heat Up A Fluid In A VesselStarted by Guest_panagiotis_* , 24 Jan 2023 |
Plate Fin Heat ExchangerStarted by Guest_shazzad1613_* , 23 Mar 2024 |
Duplication Of Psv And Flow Rate For Exchanger Tube Rupture ScenarioStarted by Guest_Platonicus_* , 11 Mar 2024 |
Firewater Theoretical Vs Actual FlowStarted by Guest_stu_* , 25 Feb 2024 |
Heat Exchanger Temperature CrossStarted by Guest_kaidlut_* , 20 Dec 2022 |
