Hi folks,
I have not been practicing process engineering since I have been in my role as an environmental engineer.
I hope you all can give some thoughts and idea about the problem that I am raising in this forum.
The current separators and surge vessel in the oil with associated gas production site are currently venting off the excess gas, as the main product is the oil.
It is well known that to prevent venting, we need to route the gas stream not to atmosphere but as an export product. Hence, we need gas compression system for the separators and maybe vapour recovery unit.
We could also convert the vent to flare, with ignition point at the end of the stack. This means we are not utilising back the gas but burn off to reduce the impact to the environment. However experience tells that these often fail and the converted flare stack will just end up venting off the gases
Are there other options that I can consider that helps to eliminate these venting or any conversion of vent to flare that does not incur cold venting in the end?
Edited by EddyHyip, 12 March 2015 - 08:45 PM.
