Flash Point For Liquid Mixtures With Prode
Posted 14 March 2015 - 08:53 AM
Posted 14 March 2015 - 11:03 AM
at 0.2 Atm you shouldn't find problems.
Prode Properties stores flammability limits and heats of combustion for most chemicals in database,
the flash point can be calculated from Lower Flammability Limits and vapor composition,
the procedure is very simple
1) given P solve phase equilibria and determine composition
2) calculate the flammability limits at T (values in Prode database are stored at 25 C) with Zebatekis correlation (LFL - (0.182*(T-tf) / Hc)
3) for a mixture, lower flammability limit is calculated by Le Chatelier method
4) iterate to find the temperature corresponding to the lower limit partial vapor pressure
that is the method but since Prode Properties allows to extract values (of each chemical in database)
you can easily modify the above or create a different procedure.
Posted 24 March 2015 - 09:34 AM
thanks marchem,
I presume hc is the heat of combustion which Prode Properties calculates with the method StrHC(stream),
is it correct ?
Posted 27 March 2015 - 11:49 AM
Hci is. the net heat of combustion,
as said by marchem, value is estimated by the function
Li(t)=Li(25°C)−0.182*(t−25)/Hci
Posted 01 April 2015 - 06:47 AM
thanks,
do you know how accurate these numbers are for mixtures ?
I have the values for pure fluids but I need those for mixtures.
Posted 04 April 2015 - 07:42 AM
pdender,
I know only a limited number of sources for flash points of mixtures,
one is DDB (Dortmund Data Bank),
comparing calculated vs. experimental data (for two mixtures) I found differences in the range 7-13 K
Hydrocarbon Dew Point Control UnitStarted by Guest_BabRafiq1_* , 05 Apr 2024 |
Sizing Of Vertical/horizontal Flash DrumStarted by Guest_Mohammad3799_* , 10 Mar 2024 |
Liquid Nitrogen DistributionStarted by Guest_Estiqaatsi_* , 23 Jan 2024 |
Kettle Reboiler Designe Rules - Position Weir, Height Weir, Liquid LevStarted by Guest_Otthigh94_* , 17 Jan 2024 |
Vessel & Tank Liquid InternalStarted by Guest_Danish John Paul_* , 03 Jan 2024 |
