Shady:
By your comments, I have to assume that your unit has operated successfully at the designed capacity and conditions for an extended period and that it presently is also operating at the design conditions - or at less demanding conditions. I also assume that ALL conditions are STEADY and continuous.
My second point has to do with process upsets, varying conditions, surges, or "spikes" in pressure, compositions, etc. Also included is consistency in process instrumentation operations and controls.
I am presuming that your clean-up section downstream of your absorber has worked well in the past and has been maintained operating at the same design conditions as before with the same, accurate analysis instrumentation as before. With all these checkpoints verified - as well as some more that are obviously related - your unit should perform successfully as before. If it isn't, there has to be a point within your process that hasn't been checked or identified as yet.
These Unit Operations are not arcane or black magic. They are very straight-forward and logical to understand, apply, and correct - if need be. Persistence and detailed review are always your best tools in applying your engineering investigation into process operations.
