i am preparing tank cool down procedure, my client asked, why product purging required after N2 interting.
I told that to stop sub-cooling inside the tank, when product % more than 95% vol. after that we start cool-down process.
Again my client is asking, why you required more than 95%?
I did not get any valid basis if you have any guideline.
Posted 23 March 2015 - 12:03 AM
Posted 23 March 2015 - 12:32 AM
rahul yadav,
Please submit the whole story about the tank, its content,...to get a proper response...
Posted 24 March 2015 - 12:29 AM
Sir,
I have new construct Propylene storage tank (Temp. -45*C), am preparing pre-commissioning procedure for TANK COOL DOWN.
Posted 24 March 2015 - 04:35 PM
Dear Rahul Yadav,
Propylene is extremely flammable (danger R12). With nitrogen, over 11,5% Oxygen can be ignition therefore, 9% of oxygen is the porcentage recommended (Storch de Gracia J.M., Industrial Security Manual in Chemical and Oil Plants, Vol. 2, McGraw-Hill, 1998, in Spanish).
You can review in Perry Chemical Engineer Handbook, 7th ed., section 26, p.77, the following recommendation:
"Inert Gas Generation.- Nitrogen is often the preferred gas for providing an inert atmosphere. In general, most organic combustible compounds will not propagate flame if oxygen in the mixtures of the organic vapor, inert gas, and air is below about 10 percent and 13 percent, with nitrogen and carbon dioxide, respectively, as the inert gases."
Your specification (procedure) exceeds the recommendations. I think if you can reach 95% you can be sure.
I hope help you.
Napo.
Posted 25 March 2015 - 12:44 AM
Dear Napo sir,
Thanks for your reply,
I need guideline for product purging,
Sulphuric Acid H2So4 Storage TankStarted by Guest_TeeEng_* , 08 Apr 2024 |
Design Criteria For Sizing Sump Drum Of Close Drain System In Tank FarStarted by Guest_AnbIran_* , 28 Feb 2024 |
Asme Code For Fiberglass Pressure Tank FeaStarted by Guest_Pheeto_* , 13 Feb 2024 |
Pressurized Deaerator Tank Exhaust Vent SizingStarted by Guest_zezima_* , 01 Feb 2024 |
Moc Selection For 98.5% H2So4 Tank Sludge CleaningStarted by Guest_lakshmi.narayanan_* , 02 Jan 2024 |
