I want to keep outlet temperature of process steam coal seam to cooling water outlet temperature using co current shell and tube heat exchanger considering sacrifice in LMTD.My question is how much practical approach should be consider in co current heat exchanger.For example if we assume 5 deg C as approach limit for counter current shell and tube heat exchanger,what shall we achieve in co current heat exchanger.What are other alternatives in design other than co current heat exchanger
Appeoach In Co Current Flow Shell And Tube Hear Exchanger
Started by S.R.Shah, Mar 28 2015 06:52 PM
Posted 28 March 2015 - 06:52 PM
Flow Switch High RangeStarted by Guest_Lyne_* , 11 Apr 2024 |
Kettle Reboiler Flow FractionsStarted by Guest_Lyne_* , 31 Mar 2024 |
Mtbe Process Flow Diagram Master Thesis.Started by Guest_sayoub_* , 15 Feb 2024 |
Plate Fin Heat ExchangerStarted by Guest_shazzad1613_* , 23 Mar 2024 |
Duplication Of Psv And Flow Rate For Exchanger Tube Rupture ScenarioStarted by Guest_Platonicus_* , 11 Mar 2024 |
