Boiler Calculations
Posted 30 March 2015 - 11:31 AM
Posted 30 March 2015 - 03:26 PM
Look at the spreadsheet prepared by Ankur: http://www.cheresour...n-calculations/
You need to know the amount of excess air in your calculations.
Posted 30 March 2015 - 10:31 PM
You need composition of the flue gas. From the composition, calculate the average molecular weight. From the average molecular weight and volume of flue gas, you can get weight. From the weight of flue gas and weight of fuel burnt, you can get the weight of flue gas per kg of fuel.
From the specific heats of the components, and the composition of flue gas (weight%), you can get the specific heat of flue gas. Specific heat is additive on weight basis.
Iso 28300 Venting CalculationsStarted by Guest_Mikemak_* , 22 Feb 2024 |
In & Out Breathing Flow CalculationsStarted by Guest_Ankit_Kumar_* , 28 Oct 2015 |
Answered
Carbon Bed Filter CalculationsStarted by Guest_kyayura_* , 25 Jul 2023 |
Flash Failure In Internal Calculations In Lng HexStarted by Guest_ebi4exploit_* , 07 Jun 2023 |
Heat Transfer Calculations For Jacketed StillStarted by Guest_Shabir M_* , 01 May 2023 |
