Please I'm simulating CO2 removal - Absorber-stripper process using HYSYS. The column converged but the problem is that I can't have the right flow, most of the streams goes to gas product composition
Can anyone help
Posted 30 March 2015 - 03:44 PM
Can anyone help
Posted 31 March 2015 - 07:07 AM
In an amine sweetening process, most of the inlet gas flow should go to the gas product.
A converged model can still be light years away from optimum. What amine are you using? How do you know you do not have the right flow? Are you trying to match plant data? If so, Hysys will not likely match actual plant data for amine sweetening processes. You need to use a more specialized tool, like ProMax.
We need a lot more details if you want us to help you.
Posted 07 July 2015 - 03:26 AM
Thank you, I eventually figured it out then, was an error with fluid package used.
Aspen Hysys - Creating A New Component And Defining PropertiesStarted by Guest_catiiiii_* , 22 Apr 2024 |
How To Find K-Values Of A Hydrocarbon Mixture On Aspen Hysys?Started by Guest_Alexis Azamar_* , 08 Apr 2024 |
Ammonium Sulfate Process SimulationStarted by Guest_amir55261_* , 06 Apr 2024 |
Extension Reaction Kinetic In HysysStarted by Guest_Ulbert Zsolt_* , 29 Mar 2024 |
Mtbe Process Flow Diagram Master Thesis.Started by Guest_sayoub_* , 15 Feb 2024 |
