Draining Condensate From A System Under A Vacuum E.g. Multi Effect Eva
heat exchanger steam trap vacuum multi effect evaporator
#1 curious_cat
curious_cat
  • 475 posts
Posted 31 March 2015 - 11:03 PM
In many applications steam traps drain condensate. But when you have steam condensing at sub-atmospheric pressures what are typical options used to drain condensate?
e.g. In intermediate effects of a Multi Effect Evaporator steam from previous effect is used to heat and this is often under a decently high vacuum. say 200 mm Hg abs.
Most articles I checked out don't elaborate much about draining the drips / condensate part.
Elevating the whole unit to make the system gravity draining seems unwieldy; you might need to elevate the heat exchangers say 20 ft?  Or do people provide a condensate pump for each such unit? Or are there special traps that can drain from a vacuum?
Would love to hear people's experiences.
Edited by curious_cat, 31 March 2015 - 11:05 PM.
#2 ankur2061
ankur2061
  • Forum Moderator
  • 2,484 posts
Posted 31 March 2015 - 11:40 PM   Best Answer
Consider using a pressure-powered pump for such a service. Refer the links below:
http://www2.spiraxsa...steam-traps.asp
For multi-effect evaporator condensate handling Spirax-Sarco and Armstrong provide their own specific solution.
http://www2.spiraxsa...pplications.asp
http://www.carotek.c...n-Guide-101.pdf
Ankur
