Dear Fellow Engineers
Kindly guide me on this.
This question is really Baffling me.
Say, there is a vessel of capacity 20 m3 in a 20 TPD plant. Now suppose i have to estimate the size of same vessel for a 10 TPD plant. Can i say that, if capacity is reduced by a factor of 2 , the vessel volume should be reduced by the same factor. ?? Is it the right methodology??
Secondly , for heat exchangers (Shell and Tube , Air Cooler etc) , can i use the same approach to estimate the heat transfer area.??
"Reason for applying this methodology: Both Volumetric flow rate and Heat transfer rate are directly proportional to mass."
Thanks in advance.
