I am attempting to size an intrusive pipe line sparger as according to the fourth page of the following document: http://www.mottcorp....esign_guide.pdf
The design is to mix ethylene oxide gas through a porous metal sparger into a water pipeline, before entering into a reactor.
The specifications are as follows (obtained from Aspen HYSYS simulation):
Ethylene Oxide Gas Flowrate: 32050 kg/hr
Pressure: 2500 kPa (362.59 psig)
Temperature: 290 C (554 F)
Volumetric Flow: 21.11 m3/min (obtained from gas equation with compressibility factor of z = 0.93)
Water Flowrate: 264200 kg/hr
Temperature: 48.44 C (77.432 F)
Volume: 4.37 m3/min
Gallon per Minute (GPM): 1155.15
I determined the SCFM to be 10002.71
ACFM = 402.79
I used the following site to size the water pipeline: http://www.tlv.com/g...-velocity.htmlÂ
Yielding the following results:
Pipe length: 100 m
Pipe ID: 0.2604 m
Water Velocity: 1.37 m/s
Flow Rate: 262.36 m3/hr
Based on the water pipeline, I assumed a sparger diameter of 1 inch, hence determining the liquid linear velocity to be 652.72 FPS (according to the provided equation in the first document linked).
The high FPS indicates a gas exit velocity designed to be 50 FPM but for a maximum of 150 FPM.
Using this maximum, the sparger area I calculated is then 2.6 feet2 , but when I try to match my area with a suitable size from the tables provided, it would seem that it is too big. Is it simply a case of an inline sparger not being sufficient for my given process?
My excel file is attached for reference, though the layout may be a bit messy.
Any help would be appreciated.
Cheers.
