Hi guys! I'm a Chemical Engineering student at University of the Philippines.
I'm currently designing a packed bed gas absorption for CO2 using Monoethanolamine (MEA)
I have tons of questions regarding this topic. BUut before that, I would like to post the given/conditions that I am currently doing.
1. Gas absorption by packed bed.
2. CO2 feed using reaction of Baking soda and vinegar (Not from a combustion reaction)
3. 15-30% MEA solution (I am using plastic column and packing materials so corrosion is minimal)
4. Lab scale absorption column (no more than 1.5m of column) <-- for study purposes only not industrial.
5. VLE data from Aronu (ScienceDirect.com
6. Gas absorption with MEA regeneration using heating coils (Not stripping and no steam)
7. The goal is to have a steady state equipment with MEA regeneration. The recycled MEA is put back to the column.
Here are my questions:
1. Is it possible to use plastic column and packing material? Won't MEA destroy it?
2. Is it possible to regenerate MEA using heating coils only and not stripping and water? I saw some chemical reactions involving CO2 loaded MEA and H2O. Is steam needed for regeneration? Is heating coil enough for regeneration?
3. Since I am using a homemade packing material. I won't be able to calculate pressure drop and diameter using Generalized Pressure Drop Correlation because manufacturers provide specific data per packing material. Given that, how do I calculate the Pressure drop and Diameter of column? I need those two so that I will know if the diameter is feasible of absorption.
4. According to Foust (1980), Height of Column is equal to Number of Transfer unit (NTU) multiplied by Height of transfer unit (HTU).
height = NTU*HTU
I have a way of calculation NTU using integration and numerical methods. However HTU is not easily calculated because Total Gas-phase mass transfer coefficient (Ky) cannot be determined. How do i get the values of Ky? Is there another way to calculate HTU other than using Ky?
Thank you very much! I am new to chemical engineering designs so I have a lot of questions. If there's any data missing just tell me I'll add.
Here's my proposed equipment diagram
Edited by Roel, 13 April 2015 - 08:03 AM.
