Hello..
can someone suggest the best method to design heat exchanger..
and also book that I can refer to
TQ
Posted 18 April 2015 - 10:30 AM
Hello..
TQ
Posted 18 April 2015 - 03:03 PM
I personally prefer "Process Heat Transfer" by D.Q.Kern for Heat exchanger design. Its a wonderful book and I would like to suggest the same to you.
Raj
Posted 18 April 2015 - 03:36 PM
A book just published that has an extensive chapter of nearly 500 pages on heat transfer is " Ludwig's Applied Process Design for Chemical and Petrochemical Plants.
Posted 19 April 2015 - 02:02 PM
Here is some preliminary info: http://www.hcheattra....com/tools.html
Another good resource is "Process Heat Transfer - Principles and Applications" by Robert W. Serth.
Posted 19 April 2015 - 07:53 PM
Posted 26 April 2015 - 08:23 AM
thanks all
Time Required To Heat Up A Fluid In A VesselStarted by Guest_panagiotis_* , 24 Jan 2023 |
Plate Fin Heat ExchangerStarted by Guest_shazzad1613_* , 23 Mar 2024 |
Duplication Of Psv And Flow Rate For Exchanger Tube Rupture ScenarioStarted by Guest_Platonicus_* , 11 Mar 2024 |
Design Gauge Pressure Inlet To A Centrifugal Compressor.Started by Guest_Mohammad3799_* , 03 Mar 2024 |
Design Criteria For Sizing Sump Drum Of Close Drain System In Tank FarStarted by Guest_AnbIran_* , 28 Feb 2024 |
