Hi! I am currently sizing a control valve but I do not know where to start. We have a control valve which was supposed to have a normal flow 323.655914 m3/hr instead of 32.3655914 m3/hr. However, as shown in the datasheet, what was considered is 10% only of the normal flow. We need to change the control valve in order to meet this normal flow wherein 10% of normal flow is the minimum flow and 110% of normal flow is the maximum flow. Thanks. What shall be the Cv of the valve?
Sizing Of Control Valve
Posted 21 April 2015 - 04:35 AM
Posted 21 April 2015 - 04:45 AM Best Answer
There are so many topics on control valve sizing on ChE forums. Have you tried the search feature?
There are also dozens of free resources on the web.
http://www.documenta.../book/cvh99.pdf
https://www.isa.org/...sa-750101-spbd/
http://www.parcol.co...1-I_05-2013.pdf
http://www.documenta...1798x012_11.pdf
http://www.swagelok....EN/ms-06-84.pdf
http://www.ascovalve...alveSizing.aspx
If you look at the control valve sizing equation for liquids, you can easily correlate the flow vs. valve Cv.
Posted 21 April 2015 - 07:23 AM
http://www.cheresour...g-and-selection
Consider these resources to support your work. Plenty of tools , papers are available in this forum , just try the search engine .
Hope this helps .
Edited by breizh, 22 April 2015 - 10:45 PM.
Posted 21 April 2015 - 03:29 PM
Minor quibble, but those significant figures look funny. 32.3655914 m3/h.
Posted 22 April 2015 - 12:00 PM
Just send the conditions to a valve supplier and let them size it for you.
Can Anyone Provide Me The Reference Datasheet For Deluge Valve?Started by Guest_Radha Krishnan Siva Kumar_* , 16 Apr 2024 |
Pump Sizing ConsiderationsStarted by Guest_panagiotis_* , 07 Apr 2024 |
Barometric Legs Line SizingStarted by Guest_panagiotis_* , 17 Mar 2023 |
Hydrocarbon Dew Point Control UnitStarted by Guest_BabRafiq1_* , 05 Apr 2024 |
Valve Cv InputsStarted by Guest_QuantumEng_* , 01 Apr 2024 |
