I would appreciate it if you could help me with problem.
I can not register any extension in hysys 8.4 i follow the procedure Customize ---> Register Extension and then i select the extension (.dll file and then I tried .edf file ) but then hysys does not register it. Also I face similar problem with the user variables. I added the user variable to the stream but it hadn't been calculated.
Problem With Registering Extension In Aspen Hysys
Started by Mahmoud Nasr, Apr 26 2015 12:15 AM
Posted 26 April 2015 - 12:15 AM
Posted 26 April 2015 - 04:02 PM
hi ! verify that u r on a windows administrator account ! i faced the same problem two weeks ago and then i discovered that it is essential to install and run the extension in administrator ! hope that this will help you !
Posted 28 April 2015 - 03:36 PM
Many thanks that solved the problem of registering the extensions but still the problem of user variables
Olga And Aspen Simulation SoftwareStarted by Guest_CHEMSTRONG_* , Yesterday, 06:05 AM |
Answered
Centrifugal Compressor Performance Curves In Aspen HysesStarted by Guest_Rafcio_* , 14 Mar 2024 |
Aspen Custom Model Won't Load Into HysysStarted by Guest_SaintLazarus_* , 21 Mar 2024 |
Aspen Hysys SimulationStarted by Guest_amazingspidermean_* , 18 Mar 2024 |
Insert A Reaction In Aspen Adsim By Compiling FortranStarted by Guest_Sara@1371_* , 12 Mar 2024 |
