In my Process Engineering specifications document, I intend to provide specifications for an Orifice Plate which is supposed to be manufactured in our plant workshop.
Referring to the attached diagram, what is the standard industrial labelling terminology for Dimension A, Dimension B and Dimension C of the Orifice Plate
Dimension A should be called "Length of Orifice Plate?
However, I'm not sure what label to use for Dimension B and Dimension C of the Orifice Plate in the attached diagram.
I hope someone can clarify about this.
Regards.
